Fender Trimming
Old Aug 22, 2001 | 02:41 PM
jkt's Avatar
jkt
Fender Trimming
I have a 1975 F-250 HighBoy that is a loyal word horse. Thus not one strait peace of sheet metal on it. so i have begain the process of trimming off 4in all around. what is the largest tire that will fit with out any rubbing? Also what do you recomend to do on the edge of the fenders to take the edge off?
Thank You
Old Aug 22, 2001 | 02:51 PM
proeliator's Avatar
proeliator
Fender Trimming
Im guessing that with a good 4 inches of fender trimming you can stuff 38s in a hi-boy, since they'll work with a 4" lift. I've used those flexible plastic strips used for edging (its U shape slips right over the edges) with good luck. I just glue them on. If you wanted to get trick you could take it to a bodyman and have those edges rolled. Make sure you use something good like a sawzall to cut those fenders, they can get messy.
If your knuckles ain't bleeding you did something wrong.
'72 F-250 "Hi-Boy" 4x4, Dana 60/HD44, FE428 @ 400+ ponies , 4-speed, custom suspension w lift, mud on black.
Old Aug 25, 2001 | 12:44 PM
fordmaniac21's Avatar
fordmaniac21
Fender Trimming
i have a 75 f-100 4x4 with 38s on it, i had to bend the front whhel wels in on the fwd section about 2". they fit fine with no rubbing
Paul E Goodman III
'75 FORD F-100 4x4
390 4 barrel edlebrock, high-rise manifold, comp cam
4" rancho lift
16/38.5x15 super swamper TSL
Old Aug 25, 2001 | 02:50 PM
BigBrownTruck's Avatar
BigBrownTruck
Fender Trimming
chamblizi
Aug 7, 2012 10:41 PM
jwcorder
35
May 27, 2012 11:58 AM
kengarchow
Jan 24, 2009 07:26 PM
mxzx
Offroad & 4x4
Aug 22, 2007 04:34 PM
