Temp. Gauge problems
Old Jan 20, 2006 | 09:51 PM
emedtech's Avatar
emedtech
I just bought a '87 F-150 302 4x4. After fixing the brakes I finally got to drive it home. It took me about 25 mins to get it home. The whole drive the temp gauge didn't move. All the others work just fime. The Fuel level, speed, battery, oil but nothing on the temp. I have no idea what to do about it. Any help would be nice. Thanks
Old Jan 20, 2006 | 09:55 PM
ford390gashog's Avatar
ford390gashog
try to locate the temp sender on the block. see if the wire has come unplugged. find the wire and ground it the gauge should peg to the right. the sender may be bad if the gauge works when grounded.
Old Jan 22, 2006 | 10:51 AM
beattle55's Avatar
beattle55
I had the same problem with my 92 460. Replacing the sensor made no difference, but a new thermostat solved the problem and the truck runs much better now.
92 460 4X4
