Sponsored by: Real Truck
No trailer running lights?
Old Jan 20, 2006 | 09:44 PM
carrcreekcaller's Avatar
carrcreekcaller
Backed my buddies boat in the lake and now I have no trailer running lights. I've got brake lights and turn signals, and I have running lights on the truck. I've checked the fuses under the dash and all apear ok. The truck is a 99' F350 4x4 diesel crew longbed w 6 speed manual. I bought the truck used and did'nt get a owners manual so I don't know exactly which fuse I'm looking for. Are there more fuses under the hood on the drivers side? Please help, thanks. ccc.
Old Jan 21, 2006 | 12:01 AM
EPDP99's Avatar
EPDP99
i think there is a seperate fuse under the hood. Check there i know i had a blown fuse and had no trailer lights.
Old Jan 21, 2006 | 01:09 AM
jake00's Avatar
jake00
I think you can download an owners manual, Aint it a lil cold for boating?
Old Jan 21, 2006 | 08:57 AM
Fishsimion's Avatar
Fishsimion
There should be another fuse box under the hood on the drivers side that has several fuses that deal with the trailer.
Old Jan 21, 2006 | 06:21 PM
tfalk's Avatar
tfalk
Can't help ya on the lighting issue...
Go to http://myford.fordvehicles.com, signup and plug in your VIN. On the Resource Center drop down, you should then be able to download the owners manual.
Old Jan 21, 2006 | 08:02 PM
Mr Vern's Avatar
Mr Vern
Just came in the house from chasing the same problem down in my 99 F250. If you look under the hood near the brake master cylinder there is another fuse block. If you open it up there are larger (Maxi) fuses and then there is a small block of mini fuses. If you are looking at the block of small fuses they are numbered from left to right, front to back. That would put the left, front most fuse as number 1 and the right front most as number 2. Look at it as odd numbers toward the engine and evens toward the fender. I believe the fuse you need should be #8 and on my rig it is a 20 amp mini-fuse. check that and see if that is blown. If not let me know and I will dig through my manual and see if I can get more info.
Good luck
