Vibrations at high speed.
If anyone help me with the following problem.
I have a 1994 XLT Ford Bronco. When I am driving at speeds near 65 and going up hill I get a vibration which seems to be coming from under the truck. If I let up on the gas it stops I then can punch the gas I can get through it and everything it fine. This vibration seems to occur more when going up hills and also occurs more if the overdrive is turned off. Does anyone have any ideas?
Thanks
If you get a minute check out the link here, it will help you to navigate around and understand this site.
https://www.ford-trucks.com/forums/s...88#post3272088
We are happy you have chosen the best source for Fords!
Enjoy FTE and The State Chapters are located at the bottom of the main forum page.
JOIN CLUB FTE -SUPPORT THE FORUMS!
See you on the boards.
Other places you can check are:
drive shaft(s)
U-Joints
rear pinion crush sleeve
engine or tranny mounts
