fuel pressure consistency
Old Jan 20, 2006 | 09:06 AM
65f100CoryE.'s Avatar
65f100CoryE.
I am having fuel pressure issues I think. I have installed a transparent filter in my fuel line between the pump and the carb. when I first start it the filter remains full. then after it starts to warm up it is like air bubbles in the filter and the fuel drops out for a few seconds then you can see it start spitting fuel into the filter then if fills up again?? and this keeps cycling. I find that if I nail it during one of the "dry spots" it stalls out like it is out of gas? then once the filter fills up again seems fine.....
wierdness at its best.... all new fuel lines and carter electric fuel pump to boot? advice thoughts considerations? it is not a life and death thing. it has never left me stranded and this is only my toy so just looking for info....
Old Jan 20, 2006 | 07:12 PM
danlee's Avatar
danlee
Blow air back into your tank through your line to your fuel pump. It could be blockage in your tank, or your Vent. Make sure that your tank vent is clear. Try your test with the filler cap off.
Old Jan 24, 2006 | 08:46 AM
65f100CoryE.
been there done all of the above.... seems a little better now that I have it running cooler. but still inconsistent level in the filter.....could the float in the carb be acting wierd... sticking closed then suddenly dropping open? not sure never seen anything like it.
Old Jan 24, 2006 | 09:20 PM
danlee's Avatar
danlee
Needle valves can stick, but that will not cause 'spitting' in the filter. Have you tried to put a fuel pressure gauge on it?
Are the fuel lines getting hot?
Are they near an exhaust pipe? It could be boiling fuel and vapor lock.
brushwolf
General Diesel Discussion
Apr 1, 2013 06:36 PM
Myfreeford
Jan 11, 2012 10:07 AM
artfd
Jan 1, 2012 08:13 PM
Flynndog
Oct 23, 2010 11:58 AM
Dodge/Cummins
Jun 19, 2008 12:31 PM
