heater knob removal...
Old Jan 20, 2006 | 03:18 AM
MEPR's Avatar
MEPR
heater **** removal...
Well i think my heater controll **** is bad. I cant figure out how to get this guy out though. Any tips on this? Thanks.
Old Jan 20, 2006 | 04:08 AM
ford390gashog's Avatar
ford390gashog
do you only have 1 speed that works? if so that could be the resistor.
Old Jan 20, 2006 | 05:15 AM
MEPR's Avatar
MEPR
nope its totally dead. Im not getting voltage at the motor but i am getting through the fuse.
Old Jan 20, 2006 | 10:45 AM
daveengelson's Avatar
daveengelson
Not sure if reading thread corrrectly. The **** is held by concentric spring. The heater control shaft inserts into **** and secured by the spring. On the underside of **** there should be a small opening(slot) where by inserting a small pointed tool of some type you release spring tention and the **** will come off. Can't recall if release by appling pressure back or forward. Don't force, does not take much and do not want to damage retainer.
dave
