Sponsored by: Real Truck
T-stat temp
Old Jan 19, 2006 | 11:23 PM
Bronco532's Avatar
Bronco532
T-stat temp
I'm going to get e Hypertech programmer and Summit Racing is giving a free t-stat with it. I can get a 160 or a 180. Other than helping to keep the engine compartment cooler are there any other advantages of running the cooler t-stat?
Thanks
Old Jan 20, 2006 | 12:27 AM
ford390gashog's Avatar
ford390gashog
neither , 195 is the correct one. a colder t stat will not keep the engine cooler but will prolong warm up times and increase cylinder wall wear and trick the computer into open loop.
Old Jan 20, 2006 | 09:29 AM
camo4stealth's Avatar
camo4stealth
I'm running a 160 stat. No problems. With all the mods I've done, even with the Diablo chip, it seemed to be running a bit lean. Cooler engine temp will have the computer richen the mixture a bit. It runs fine.
Old Jan 20, 2006 | 10:13 AM
F250Wheels's Avatar
F250Wheels
A 160 stat is great for A hot rod with A short life span, I wouldn.t do this to my truck.
Everybody thinks the factory engineers are dumb, but theres good reason for the stock 195 stat.
Old Jan 20, 2006 | 10:55 AM
Bronco532's Avatar
Bronco532
I'm thinking along the same lines as F250Wheels...I wouldn't think the 35* would make a big difference but they put at a 195 in for a reason. I do like to quick warm up on the cold days too. I can't see the point in changing it unless it is really doing to make some type of improvements.
Thanks
