Squeaking Issue
Old Jan 19, 2006 | 10:03 PM
xTritonV10x's Avatar
xTritonV10x
Squeaking Issue
Recently, one of my belts decided to squeak. It will only do it when the engine is idleing, but I have an issue with squeaks, they really get on my nerves. I am pretty sure it is coming from the AC but I don't know how to fix the problem, I tried oiling and that provides a temporary fix. Any ideas?
Old Jan 19, 2006 | 11:01 PM
frederic's Avatar
frederic
Replace the belt.
Old Jan 20, 2006 | 12:08 AM
spidk43's Avatar
spidk43
don't oil or lube, it will worsen the problem in the long run and with future belts. Replacing the belt is the only fix now. There is an article on squeaky serpintine belt on the home page of FTE. I would read that, I found it quite helpful.
https://www.ford-trucks.com/article/...elt_Noise.html
Old Jan 20, 2006 | 02:54 PM
mdjohnson's Avatar
mdjohnson
My A/C compressure squeaks when it is enguaged even with a new belt.
Old Jan 20, 2006 | 03:30 PM
spidk43's Avatar
spidk43
did you use a scotch brite pad and brake cleaner before replacing the belt? Just a thought...
Old Jan 20, 2006 | 05:51 PM
xTritonV10x
Thanks for the help guys, I'll try what you suggested.
