switch?
Old Jan 19, 2006 | 09:50 PM
1972ford_f-100's Avatar
1972ford_f-100
Lightbulb switch?
i have an older f100 with a normal everyday 65 amp external regulater alternator, i would like to upgrade to a 200 amp,with internal,wut do i need to do and change
Old Jan 19, 2006 | 11:22 PM
cheez67's Avatar
cheez67
what kind(brand) of alt are planning on using?
Old Jan 20, 2006 | 03:33 PM
Franklin2's Avatar
Franklin2
Yes, what kind. A 200 amp sounds like an aftermarket type, possibly with one wire hook-up?
Old Jan 20, 2006 | 03:57 PM
1972ford_f-100
i was planning on useing a standerd motorcraft 200 amp 3g alternator
Old Jan 20, 2006 | 05:29 PM
cheez67's Avatar
cheez67
i was not aware that they made that style in that high of output. is there any letters on the plug for the regulator such as i,s or L ?
Old Jan 21, 2006 | 08:08 PM
Franklin2's Avatar
Franklin2
Here's a wiring diagram for the newer alternator. The only wire you need to keep up with is the one that comes from the light if you have an alt light in the dash, or the wire from the keyswitch if you have a ammeter. The rest of the original wires will go, and you will run new heavier wires to the battery and or the starter relay.
