PInch Joint??
Old Jan 19, 2006 | 05:20 PM
youngguy's Avatar
youngguy
PInch Joint??
I have recently had a chattering noise coming from the drivetrain of my 2001 Explorer 4x4. After taking it to a driveline shop they mentioned it may be a bad pinch joint(joint that connects the front drive line to the transfer case). I have never heard of this type joint and the local Autozone does not carry it. It is obviosly not a U-Joint. Can anyone give me some info on replacing this joint and where I might find one.
p.s. The explorer is a full time 4x4 from what I understand. Is this a normal option on these explorers?
Thanks
Old Jan 19, 2006 | 05:33 PM
JerrySimm's Avatar
JerrySimm
All wheel drive (AWD) is a common option on the V8 explorers. If you have 4wd, there will be a selector that says 4WD Auto and 4WD HI and 4WD Lo. As to the pinch joint, I'm sorry but I'm no help. I've always had 4wd's.
Old Jan 20, 2006 | 11:03 AM
youngguy's Avatar
youngguy
Thanks for the reply Jerry. My Explorer has a 4.0 liter but from your description it is definitely an AWD. I am going to replace the pinch joint today so hopefully it gets rid of the chattering noise I've been getting.
Old Jan 20, 2006 | 03:11 PM
youngguy's Avatar
youngguy
After talking to the driveline shop, I found that I was mistaken concerning the part name. It is called a plunge joint and not a pinch joint. Anyhow, it is in the process of getting replaced as well as a new spicer(greasable) front U joint.
herby666
Apr 4, 2013 12:06 AM
herby666
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Apr 3, 2013 04:13 PM
1983F1503004x4
Mar 5, 2013 11:57 AM
89 bronco II
Oct 6, 2004 08:30 PM
JTD1972
Apr 10, 2004 10:54 AM
