Aerostar Ford Aerostar
Tool Heater Core Repairs
Old Jan 19, 2006 | 03:28 PM
96_4wdr's Avatar
96_4wdr
Autozone loaner
http://www.autozone.com/in_our_store..._hose_disc.htm
Old Jan 19, 2006 | 04:24 PM
aerocolorado's Avatar
aerocolorado
Good information. Potential users should be aware these tools are not a panacea for the quick disconnect coupling. I bought two (one like this and a genuine Ford one) and neither performed as well as I expected. I fully expected to just slide the tool over the coupling window and give a tug and off it would come. In reality, it still required considerable up/down twisting with one hand while using the tool with the other hand.
Old Jan 19, 2006 | 11:20 PM
93nighthawk's Avatar
93nighthawk
Cool tool, but it looks like the sawz-all would still be easier.
Old Jan 20, 2006 | 05:34 PM
mediaman67's Avatar
mediaman67
That tool does work though, and it was faster than if I used my dremel to take them off...
the key to using it, is once you are in the nitch, you push the tool toward the firewall, and with the other hand, yank on the hose...
I didn't replace the heater core when I did mine (knock on wood, it will still be ok for a while!)
The fun part of the whole job was clicking the new ones back on... nothing could be easier! No leaks, and a perfect connection, just like OEM
I actually ended up keeping the tool, because out of about 3 Autozones in the area, ONE store had it, and this was their only one... worth the 12 bucks I paid for it... esp if I ever need to use it again.
One word of advice... if you are re-using the same hose, and you only needed to remove them for replacing the core, get a couple or 3 of the white/clear clippys from ford... and the o rings as new too... (I think they come with them) I ended up distroying one of them, when I took it off the nipple of the core... but I was replacing the hoses anyways, so it didn't matter...
Peace
Bob
Old Jan 20, 2006 | 10:03 PM
cbr900's Avatar
cbr900
My disconect couplers on the water lines just blew apart one day now I have them wired together they dont leak though.
Norton72
Sep 5, 2019 02:40 PM
mattnj
16
Nov 1, 2016 09:20 AM
84dieselguy
Aug 21, 2011 08:44 AM
boffah
Jan 19, 2009 04:21 PM
TexasGuy001
General Automotive Discussion
Aug 19, 2008 11:42 PM
