Does anyone know if all ford transmissions use the same hook up for the mechanical hook up on the transmission? My 82 F100 currently has the SROD (Single rail 4 speed overdrive) I want to replace it with a Tremec TKO 500. I will end up with better gear ratios too:
It should bolt in just fine. I called these guys not far from me and they know their transmissions. I hate my current 2nd to 3rd gear leap, the tko should fix that problem with the 1.34 3rd gear.
