Fuel line integrity
Old Jan 19, 2006 | 01:59 PM
grnburg's Avatar
grnburg
Fuel line integrity
I was replacing the O-rings and caps on my fuel return system and first thing I found is that my #1 injector pump to injector fuel line is broken. Should I be concerned about the others? Its an '86 F350 Crewcab dually w/ 6.9IDI, C6 w/ DNE Aux trans (disabled- wires cooked away). The Odometer reads 008300, how many times over is anyone's guess; while the last owner used for a 'ranch truck' the ones before him did alot of pulling horse trailers. I wonder should I pull and inspect the injectors or maybe have them cleaned just to be safe?
Old Jan 19, 2006 | 08:19 PM
Dave Sponaugle's Avatar
Dave Sponaugle
It never hurts to have the injectors pop tested. They check the opening pressure and spray pattern when this is done. I just had all mine checked and repaired 4 that were not spraying right and two that were slobbering fuel non stop.
Engine runs much better with more power now.
I spent 287 dollars to do all that. Money well spent.
Old Jan 19, 2006 | 08:58 PM
wh336fire's Avatar
wh336fire
I had one injector line get a pin hole in it while I was on a road trip . Had to drive it about 50 miles with it shooting diesel all under the hood . Kept a fire extinguisher in my lap..lol.
My ip rebuilder says the lines can fail due to the engine vibration .
I have seen a flexible line that you can use in case of emergency , I plan on buying one and keeping it in my truck to get me home next time .
Old Jan 19, 2006 | 10:26 PM
grnburg's Avatar
grnburg
Question
Thanks for the input guys. I got under the hood a little bit this evening. I wanted to put in the new line and see where the copper washers that came with my seal kit went. Turns out they are the bottom seal of my blackened, crud covered injectors. (at least I tend to be a quick learner) I brushed the funk off the sides of 'em and cleaned the tips w/ carb cleaner and a tooth brush. What's the best way to clean the port inside the block? I wiped #s 1, 3, 5 & 7 with a clean rag on a long screwdriver and got a lot of soot from the bottom of the whole, I'm afraid of plugging a hole doing it though.
Old Jan 20, 2006 | 07:23 AM
wh336fire's Avatar
wh336fire
While you have your injectors out you should have the tested for proper operation .The spray pattern may not be correct or the could leak .
I cleaned out the holes in mine the same way you did . A shop vac may get some of it .
Old Jan 20, 2006 | 08:12 AM
grnburg's Avatar
grnburg
I cleaned out the holes in mine the same way you did. A shop vac may get some of it .[/QUOTE]
I geuss it worked OK? I have a vacuum attachment for cleaning detailing and computers (5/8' hose & attachments) I am going try.
Old Jan 20, 2006 | 06:21 PM
wh336fire's Avatar
wh336fire
Yep , mine is purring right along .
