gets so much gas it floods while I'm driving
my 87 br2 starts out running fine i drive maybe five miles and it goes from 70mph to 15 mph i figured out its getting to much fuel but cant quite figure out why I've checked the vacuum/ emission line there all routed correctly just had the timing done i just bought the truck and I've put too much in it to quit know any suggestions
finally got to pull the codes they were
koeo 31,41,53,63,29
koer 21,22,12,31
any help with this im thinking my o2 and tp sensors but not for sure. its a new o2 but tht dosnt always mean its working so ill take it back to a.z. and swap it out cant hurt nything but time so hopefully it fixes the problem and can move on if it dont its gunna get park and im getting another vehical monday but i would relly hate for it to sit like that thing has givin me a bigger headach then i needed right now but if you got any input on this let me know
btw how do i clear my codes
koeo 31,41,53,63,29
koer 21,22,12,31
Did you check for gas in the FPR vacuum line?
For the....
21, was the engine up to normal operating temperature?
22, check the electrical connection to the MAP and the vacuum line.
12, is an IAC problem, was the ECU able to control the idle speed when you were running the KOER test.
31, is an EGR code, I don't think this would cause a rich condition. I can send you the pinpoint test for this one onxce youo clear the others.
For the....
i don't know how to clear the codes and i took the egr off it is clogged i also found that its leaking and no the ecu want able to control the idle speed but i have noticed that when i unplug the iac the rpms drop to where there supposed to be at normal operating temp and the engine was at normal operating temp it was low on coolant i was going to get a new egr tps and o2 sensors tomorrow if there all available at az because i need to fix it all for emissions anyway so but if i can clear the codes then i can narrow it down some more and i would greatl appreciate the pinpoint test is there and pis available to show the vacume line routing becides the the diagram under the hood hope fully after i get taxes i can pay a tech to tune it up a little bit
To clear the codes you can follow the procedure in the link, pulling eec-iv codes, in the tech info thread at the top of this forum or disconnect the battery for 15 minutes.
Once you have that done I would take it out for few 15-20 minute trips and pull the codes again.
The idle speed should drop below normal when you disconnect the IAC, do you have any vacuum leaks or did someone adjust the throttle plate stop screw?
If you were low on coolant that could have caused the code 21.
Since you found an EGR proble it can't hurt to replace parts there but I would hold off on anything else until you get a fresh set of codes.
