Sponsored by: Kumho
Brake Lines
Old Jan 18, 2006 | 11:18 PM
99ExpHere's Avatar
99ExpHere
Brake Lines
Whats the recommended brake lines i should use for a 91 explorer sport 4x4 and does anyone know how to change them??
Old Jan 19, 2006 | 05:25 PM
andym's Avatar
andym
You need to use steel brake lines that are designed to be used as brake lines. Don't use copper or anything else. If you're making your own, you'll need a flare kit to make the ends. To change them, just remove the old ones and put new ones on. Obviously, bleed the brakes thoroughly when you're done.
Old Jan 19, 2006 | 06:23 PM
99ExpHere's Avatar
99ExpHere
okdokie thanks
