Exhaust Install help???
Old Jan 18, 2006 | 09:06 PM
anger65's Avatar
anger65
I just got a Banks Monster Exhaust and want to install it tomorrow morning.
I'm trying to find tips on removing the old exhaust, installing the new.
I'm most concerned with the Turbo area with getting the T.O.P out and new one in.
I'm sure this has been covered before, so as I search to find that thread, if someone could point me in the right direction it would be greatly appreciated.
Thanks
Old Jan 18, 2006 | 09:24 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
i just cut my old system off with a sawzall. it is nice to cut the pipe in front of the transmission crossmember. if you want to take the old system off without cutting it, you have to remove the transmission crossmember because the first joint is past the crossmember and there is no other way to get it off (sans cutting) without dropping the crossmember.
Old Jan 18, 2006 | 09:43 PM
1984_355w's Avatar
1984_355w
I used the flame wrench. Surprisingly to me as well, removal and installation of the 4" dp was a lot easier than the rest of the 5"!
Old Jan 18, 2006 | 10:05 PM
Aarkie's Avatar
Aarkie
Just be careful with the downpipe and the dip stick to the transmission. You will need help with it.
Old Jan 18, 2006 | 10:13 PM
DiscountPowerPrt's Avatar
DiscountPowerPrt
I hope your not installing the Power Elbow, because I would rather vomit in an ice cube tray and eat them all day rather than pulling the turbo. Some say it can be done on the truck without removing it, but I'd like to see that one. Even with the Turbo on the work bench I still broke two of those little sockets trying to break those bolts loose. I guess anything can be done, but Im not lookin to try that one again.
Old Jan 18, 2006 | 11:11 PM
jtharvey's Avatar
jtharvey
Yeah, just cut the old one off. I used a sawzall like stroking did. I tried to remove the clamps, but it was no hope. 4 years of road grime had taken their toll, and I had to cut it off to get the old system out. My old downpipe (TOP) came off rather easily. That V-band clamp may be a little stuck on though. You might spray some liquid wrench on it before you start to help get it off the stock system. Fortunately, I didn't need help when installing my system, the same Banks Monster Exhaust you have. There was plenty of clearance between the exhaust and the transmission dipstick. I didn't have to bend anything. Maybe I just got lucky.
Old Jan 19, 2006 | 12:29 AM
anger65's Avatar
anger65
No power elbow here... I don't think I need it.
So when removing the downpipe from the turbo exit, do you just loosen the clamp, or do you unbolt the "housing" around the pipe?
Old Jan 19, 2006 | 01:52 AM
jtharvey's Avatar
jtharvey
Should be just loosen the clamp. The "housing" around the pipe I believe is just a heat shield that will not be used on your new exhaust. You could take it off if it facilitates the removal of the pipe. Just don't go loosening any bolts on the turbo housing itself.
Old Jan 20, 2006 | 07:57 AM
fordtrkpuller's Avatar
fordtrkpuller
FTE *******
Use the recipricating saw (sawzall) and whack that bad boy off just where it turns under the truck. By a case of beer and invite a buddy to come help, get the clamp off of the turbo exit/downpipe and wriggle it while prying it. THey tend to come together tight, so they dont just slide right off. Once you get it off, getting the Bank's exhaust on is pretty easy. Dont forget to chill the beer before you get your pal over there, or may leave you part way thru the job. Very important...you HAVE to have the beer for the job to go correctly!
Old Jan 20, 2006 | 08:15 AM
PSNut's Avatar
PSNut
Gotta get me one of those flame wrenchs!
Old Jan 20, 2006 | 10:30 AM
anger65's Avatar
anger65
Got the beer, found a sucker... I mean buddy, to come help me out tomorrow.
Lookin forward to get it done! Thanks for the tips
Next project, Dohahoe Racing lift!
