dual tank selector valve ????
Old Jan 18, 2006 | 08:09 PM
ford user's Avatar
ford user
Question dual tank selector valve ????
do i have to drain the tanks to change this valve ??? . i just tried to change this valve and fuel was just dumping out. i had enuff gas on my body to run my truck across the county line and back..
Old Jan 19, 2006 | 05:20 AM
srercrcr's Avatar
srercrcr
What year?
If it's fuel-injected, you'll have to release the pressure in the system.
If carbed, you'll get some drainage from what's in the line, but then it'll just drip.
Invest in a Chiltons.
Old Jan 19, 2006 | 02:47 PM
ford user's Avatar
ford user
it's a 86 302 efi. yes i should invest in a book, i guess i am getting cheap from buying so many new parts the last couple months. i never thought that a ford could break down. i'm allways driving the ford to get parts for the chevy.
Old Jan 19, 2006 | 04:41 PM
torquemeister's Avatar
torquemeister
Since it's EFI, there's a fuel pressure release switch in the cab on the passenger side floorboard. Once you disconnect it, you'll only have minimal draining when you disconnect any of the lines for dual-function reservoir. There is no need to drain the tanks
Buy a Haynes manual for $12, it will really help and will save you more than $12 in the long run.
Good luck!
-Chris
