96 f250 t-case problems
Old Jan 18, 2006 | 06:09 PM
jeffj2689's Avatar
jeffj2689
i have a 1996 f250 351w and when you put the transfer case into N and then try and put it back in gear it grinds. The only way i can shift it out of nuteral is to turn off the truck then shift it out of nuteral and start it agin. any info would be appreciated. thanks
Old Jan 18, 2006 | 06:42 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Jan 18, 2006 | 09:57 PM
DaveBowman's Avatar
DaveBowman
Thats the way they work, don't worry about it. If the transfercase is in netural there will be no load on the output shaft of the transmission so it will start to spin if its out of park. Even if the transmission is put in netural it will still continue to spin the output shaft. Try to put the transmission in park and the park pawl just grinds. Try to put the transfercase in gear and the gears there grind. Only was to put it in gear is to stop the engine to get the gears to stop turning
Netural on the transfercase is useless except if you want to tow the truck and not have it turn the transmission
Old Jan 19, 2006 | 05:18 PM
jeffj2689's Avatar
jeffj2689
thanks for the info. this is my first 4x4 so i am still learning
