dove heads?
Old Jan 23, 2006 | 04:29 PM
  #31
Bill_Beyer's Avatar
Bill_Beyer
Cam duration is long & short and is measured in degrees. Lift is high & low and measured in inches. Camshaft duration is simply a measurement of how long the cam lobe keeps the valve open relative to crankshaft rotation. Remember the crank rotates 2 deg for every 1 deg of the cam so the crank has to rotate twice or 720 deg for every 360 deg of cam rotation. A cam with 270 deg duration opens the valve for 270 deg of the total 720 deg that the crank rotates.
Old Jan 24, 2006 | 12:12 AM
  #32
kermmydog's Avatar
kermmydog
Monsterbaby
Thanks for your input on this subject, I have an 86 F250 4x4 C-6, and I have been debating this subject in my mind for awhile now and I think after hearing you I will just rebuild a set of stock heads, do alittle porting on the exhaust, add a cam and call it good.
Thanks
Old Jan 24, 2006 | 12:23 AM
  #33
ron_29_1973's Avatar
ron_29_1973
if u put the dove head's on the 79 it would have around 9.5 comp if you want the 10.5 comp you have to use the 1968 to 1971 piston's to go with the head's.
Old Jul 21, 2024 | 10:03 AM
  #34
GGF350's Avatar
GGF350
Originally Posted by monsterbaby
Ok we will just agree to disagree on this one. But for reference I consider $100 for a set of stock factory heads stupid money unless your talking PI or SCJ heads then I might consider going all the way to $250 for a rebuildable pair.
Just to drag you into something a bit different,, because you seem to know your stuff.. I have a 1990 460 EFI (385) what type of heads are on it and should I search out something different.
I have not pulled it yet,, so I don't have casting numbers...I would like to once I piece things together end up in the 450+ HP range.. Just looking to save a few $ along the way by asking ??'s I read thru the above conversation..
Thanks....
Old Jul 21, 2024 | 03:52 PM
  #35
cougrrcj's Avatar
cougrrcj
This thread is 18 years old!
Are you wanting 450 flywheel HP? At what RPM? Usage of the truck?
Scotty J aka 'The Mad Porter' has 450hp EFI packages... Parkland Auto Machine - Home
Old Jul 21, 2024 | 05:49 PM
  #36
GGF350's Avatar
GGF350
yeah it is an oldie, 450 to 500 at the crank, just a truck occasional hauling of stuff..
Old Jul 22, 2024 | 09:42 AM
  #37
cougrrcj's Avatar
cougrrcj
For 'occasionally hauling stuff', you don't really need high RPM horsepower, you need low- to midrange RPM Torque.
Your truck has E7 heads, which are ~97cc and small valves. 88-92 pistons have a 7cc dish, and 1.752 compression height
The '93-97 7.5s use F3 heads, with 92cc and a slightly larger intake valve.
Ford changed pistons for the '93-up that have larger 15cc dish, but taller 1.772 compression height, and when combined with the smaller chamber heads actually keeps the compression ratio the same at 8.6. The taller pistons made the 'quench' part of the piston-chamber a bit closer to promote swirl that helps to reduce the chance of detonation/pinging.
My recent '95 rebuild used Keith Black 137 1.772" compression height flat-top pistons with a 2.5cc valve relief, the stock (rebuilt) F3 heads (shaved .005 for straightness) for a compression ratio of near 9.5:1, a mild computer-compatible Comp XE256H cam, mid-length headers and a mass-air SEFI conversion. All told, this increased HP and Torque by a bunch. The engine build software predicts ~430 flywheel hp at 5000, and more than 400lb/ft flywheel torque between 2000 and 5000rpm, with a peak of 490 at 4000. Factoring in accessory and drivetrain losses, we're looking at predictions of 360rwhp and 420rwtq.
Engine rebuild costs came in at around $3000, and I spent another ~$2000 for the rebuilt heads, headers, new radiator, new water pump, timing cover, hoses, belts, spark plugs, wires, and the (used) Mass-air wiring
deere81
Apr 12, 2011 12:52 PM
CaptainIPSC
Jan 2, 2011 09:48 PM
J Hodges
Dec 14, 2009 09:31 PM
f100reborn
Mar 17, 2005 08:32 PM
Ds7776
Sep 26, 2003 12:45 AM
