Timing Question?
Old Jan 18, 2006 | 09:59 AM
cradar69's Avatar
cradar69
Cool Timing Question?
I have a 1996 F-150 with a 302cid. I had a Ford dealer change the Hall Effect sensor in the distributor. WHen they retimed the truck it was so far off I could not go above 55 MPH on the highway. I set the timing to 0 degrees with the SPOUT connector removed. Does anyone know what it should be set at? I am obviously reluctant to trust a dealer again. Not that I ever did in the first place.
Old Jan 18, 2006 | 10:05 AM
fonefiddy's Avatar
fonefiddy
Stock is 8 DBTDC. Most peeps bump it up to 10-12 degrees
Old Jan 18, 2006 | 10:24 AM
EPNCSU2006's Avatar
EPNCSU2006
Stock is 10°, start there.
Old Jan 18, 2006 | 08:58 PM
cradar69's Avatar
cradar69
Thanks for the help. This is obviously with the SPOUT connector removed right?
Old Jan 18, 2006 | 09:16 PM
subford's Avatar
subford
Right, 10° DBTDC with the SPOUT connector removed.
