tach installation
Old Jan 17, 2006 | 06:18 PM
turdbird's Avatar
turdbird
tach installation
i have an aftermarket tach, how do i install it on my 96 300 f150 5spd?
Old Jan 17, 2006 | 06:22 PM
ford390gashog's Avatar
ford390gashog
there should be 4 wires. the instructions are also in the box. one goes to ground.one to a switched hot wire , one goes to the dash lights and the ohter goes to the negative side of the coil it may be marked tach test.
Old Jan 17, 2006 | 06:32 PM
rhetor's Avatar
rhetor
red: 12v+
black: 12v-
white: instrument light positive
green: negative side of coil
Old Jan 17, 2006 | 06:48 PM
turdbird's Avatar
turdbird
so all i have to do is hook it up to those wires?
Old Jan 17, 2006 | 06:49 PM
ford390gashog
yes but the wires may be different colors.
Old Jan 17, 2006 | 10:46 PM
brownstraightsix's Avatar
brownstraightsix
If you have your dash open, just tap on to the radio wires. All you'll have to do is run the green wire to the ground side of the coil. You might be able to tap the coil wire right under the dash. All you have to do is trace the wire (even though they split at one point).
Here are the colors for the radio:
blue = dash lights
black = ground
yellow = live 12v source (dont tap on the wire that is hot at all times)
Old Jan 19, 2006 | 09:15 PM
turdbird's Avatar
turdbird
are you sure that those colors are for a 96 f150?
Old Jan 19, 2006 | 10:20 PM
brownstraightsix
Ya, I'm pretty sure. If not, just test which wire is live with the key to the off position. That's the one you DON'T WANT! So just take the other wire (it really should be yellow or red) and tap your red wire onto it. Then, find a blue wire that goes to the heater or the radio or any other component that illuminates and tap the white wire onto that one (make sure that it is live with lights on and cold when lights are off). The only thing left is to find the wire that comes from the ground side of the coil. If you don't want to take a chance tracing it inside, just bring your green wire through the firewall and tap it right next to the coil. You can't go wrong.
Old Jan 21, 2006 | 06:25 PM
turdbird's Avatar
turdbird
this installation is nowhere as easy as you guys say it is, there are three wires leading from the coil to the power distribution box, there is no way of telling the tach signal in the instrument cluster harnesses, do you know the exact color of either the tach wire in the harness, or the color of the signal wire from the coil?
Old Jan 21, 2006 | 07:51 PM
Raven95150's Avatar
Raven95150
On the coil there should be 2 harnesses that plug in to it. The one you want is the one closer to the passenger side of the truck and it is the wire closest to the front of the truck in that harness. It should be tan with either a yellow or white stripe. (I couldnt tell for sure since it is dark outside right now)
As for the other 3 wires on the tach, I just hooked mine into the fuse panel..the red one goes to a circuit that is hot when the igniton is on, the white one goes to the dash light or tail/parking light circuit, (if you hook it into the dash light circuit, the tach will get brighter/dimmer with the dash lights when you adjust them) and the black wire hooks to any place that is a good ground.
Old Jan 27, 2006 | 05:51 AM
bass2catch's Avatar
bass2catch
i just installed a tach in my 1996 f150,300 six ,it was very easy only took about 15-20 min. the coil wire is the one at the front of the engin .tan and yellow .
Old Feb 14, 2006 | 10:14 AM
mr_malina's Avatar
mr_malina
I have had tach on my 1991 F150 for about 3 years now it works fine except for the fact when I turn on my turnsignals the needle in the tach jumps up and down. Any ideas on why this would happen?
Old Feb 14, 2006 | 09:31 PM
NavyMIDN08's Avatar
NavyMIDN08
sounds like the hot wire that you wired the tach into was also somehow connected to the blinkers, just run a new wire and it should solve the problem. i did that with my brakes on accident once... should have seen the cops face when he tried to tell me why he pulled me over, "there's something wrong with your lights, they uh... well, there is something wrong with them..."
Old Feb 15, 2006 | 12:14 AM
mr_malina's Avatar
mr_malina
I know for a fact that the wire is tied into one of the 3(I think) wires coming off the distributor. I dont see what that would have to do with a turn signal.
