gearshift column ???
Old Jan 17, 2006 | 06:08 PM
jcg82's Avatar
jcg82
Is there a safety switch in the gear column. And sometimes when I put the truck in park I get out the truck and it starts rolling. Then I push it up a little bit and it catches. Any info on this would be helpful.
Old Jan 17, 2006 | 06:11 PM
ford390gashog's Avatar
ford390gashog
there is a NSS on some. but you may need to adjust the shifter.
Old Jan 17, 2006 | 06:49 PM
jcg82's Avatar
jcg82
I assume NSS means nuetral saftey switch.
Old Jan 17, 2006 | 06:50 PM
ford390gashog
yes it does.
Old Jan 17, 2006 | 08:41 PM
76supercab2's Avatar
76supercab2
Assuming auto trans couple of things.
1. It could be the linkage needs to be adjusted but more likely
2. The shift collar on the top of the column breaks and causes the shift positions to change. Eventually the collar will completely break and you can be stranded. I would pull the wheel, turn signal switch and check the collar for cracks.
3. The parking prawl in the trans could be worn.
or
4. The cab mounts could be rusted through allowing the cab to sag and chaging the shift linkage geometry.
My guess would be number 2. Assuming you've never pulled the trans, the linkage shouldn't just go out of adjustment.
Old Jan 17, 2006 | 10:57 PM
Mil1ion's Avatar
Mil1ion
In 1978 and 79 there was safety recall for this problem.
This same thing cost me $1200.00 last year when my truck hit an Escape on a dealer lot.
What year is your truck....you didn't say
Old Jan 18, 2006 | 05:00 AM
jcg82's Avatar
jcg82
Its a 79 guess I should have said in beginning of the thread.
