brights
Old Aug 21, 2001 | 08:14 PM
79fordslug's Avatar
79fordslug
brights
when I go to hit my brights, the headlights turn off completely. Is it something in the switch, or the bulbs themselves?
Old Aug 21, 2001 | 08:25 PM
shortbedford's Avatar
shortbedford
brights
hey fordslug i ave actually seen both high beams burned out atthe same time but not very often. you probally have a bad dimmer switch see if you have 12 volts to the head lites. if you do then you have bad bulbs if not ???? dimmer switch ??? hope that helps some.
Old Aug 21, 2001 | 11:55 PM
Nod's Avatar
Nod
brights
Hey Fordslug, I had the same problem on my 72 F 100. I had a dead short in the high beam wire that runs past the battery box.Over the years vibration caused the insulator to wear thru at the battery box, so every time I turned on the high beams they cut out emediatley. I found the problem after much searching and reinsulated the wire then cut a length of plastic line lengthwise and forced it over the wire at the point where it wore thru. That was about 11 years ago and the lights still work fine.Good Luck, hope this helps.
"bowties in the rearview mirror"
Old Sep 5, 2001 | 01:04 AM
Boomer95's Avatar
Boomer95
brights
Its the floor dimmer switch, just wd-40 the hell out if it, and work the switch for a while.
Old Sep 5, 2001 | 09:35 PM
MEPHISTO_XES's Avatar
MEPHISTO_XES
brights
Just replace the floor dimmer switch(like Boomer said). I've run across this in ALL older big3 brands.
Garett
http://members.tripod.com/mephisto_xes
Old Sep 5, 2001 | 11:33 PM
77_f250_460's Avatar
77_f250_460
brights
could just be a bad ground somewhere along the line, these trucks are notorious for having ground problems...
Old Sep 6, 2001 | 10:20 AM
79fordslug's Avatar
79fordslug
brights
bought a used switch for $1.50 at the junk yard. Fixed the problem. Thanks for all the responses
Old Sep 6, 2001 | 12:14 PM
cigarxtc's Avatar
cigarxtc
brights
