Torque Converter
Old Jan 16, 2006 | 06:31 PM
fordflaresides's Avatar
fordflaresides
Torque Converter
How do you tell if your torque converter is bad?
Old Jan 16, 2006 | 07:33 PM
Clubwagon's Avatar
Clubwagon
If the truck moves, the torque converter is working. That the most basic. Next would be the converter clutch, if it has one.
It would help to know what kind of problem you have and what truck and transmission.
Steve
'95 Clubwagon XLT
Old Jan 16, 2006 | 08:24 PM
classicfordfreak's Avatar
classicfordfreak
If the truck moves then the torque converter is working properly but i have seen one that made alot of noise. What is the vehicle?
Old Jan 16, 2006 | 09:19 PM
The SnoMan's Avatar
The SnoMan
Not true. I have seen them with bad stator clutches (one way clutches) that when they co bad there is not torque multoplication in them. They are just nothing more than 1 to 1 fluid couplings when that happens and they can be quiet too when this happens. They also tend to slip a bit more are lower RPMs when this happens and feel a bit loose too. The stotor redirect the oil to boost torqe and rides on a one way clutch they lets it overrun as RPM increase to reduce torque factor. when clutch is bad, there is no boost.
