Dirty motor compartment
Old Jan 16, 2006 | 05:48 PM
Hotwheelbill's Avatar
Hotwheelbill
Is the grit and dirt in the engine compartment normal for a diesel? It just seems to buld up fast.
Old Jan 16, 2006 | 05:59 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
most of the oil and "crap" down below the turbo (mainly around the orange intake boots) is from the boots seeping oil out of them. this comes from the closed-circuit crankcase vent system, which vents the oil mist into the air intake, and this in turn coats the entire intake system with an oily residue. it seems as if the oil likes to permeate it's way through the boots and then when dust hits the oil, it just sticks. when i did my CCV mod, i took the whole intake system off (minus intercooler) and i cleaned all the connections/boots/pipes etc. made it alot nicer. until that happens, simplegreen and a nice hosing will wash away the junk.
Old Jan 16, 2006 | 06:05 PM
Hotwheelbill
I will clean everything when I put in the afe stage II kit. I think.....know that I will do a ccv mod at that time too. Thanks for all the info.
Old Jan 16, 2006 | 06:19 PM
whitesdford's Avatar
whitesdford
just make sure you dont get any water down the turbo if you have the air filter, etc off.
