some opitions please
Old Jan 16, 2006 | 04:16 PM
puffer's Avatar
puffer
theres a company that has a rebuilt turbo with a different cold side wheel it has 6 fins instead of 8 fins for faster spooling up and its only 465.00 with gastets for the pedastool. i decided to change the turbo due to the leak and hope that by upgrading a little it will help.
Old Jan 17, 2006 | 07:00 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Gotta picture or a link? Sounds more like a scam than an upgrade.
Old Jan 17, 2006 | 11:52 PM
puffer's Avatar
puffer
the turbo is for sale by ats
Old Jan 18, 2006 | 08:51 PM
cookie88's Avatar
cookie88
FTE Emeritus
I'd like to offer a more informed opinion, but I'm not seeing anything besides the Aurora systems on their site...and those are not cheap.
Old Jan 18, 2006 | 08:58 PM
barebackjake's Avatar
barebackjake
the price sounds like its for there ported exaust housing. that will make the turbo spool faster but i think for stock fuel the wastegate is not needed. a non wastegated 1.0ar housing will spool the turbo faster for about $150 a custom intake side with a larger compressor wheel with the 1.0ar on the other side works great. im running a similar setup the hybrid setup but flowing 1250cfm.
Old Jan 18, 2006 | 11:04 PM
puffer's Avatar
puffer
this is the place i called and talked to mike i hope im not breaking any rules
http://www.jhdiesel.com/atspricing.htm
Old Jan 19, 2006 | 07:27 PM
cookie88's Avatar
cookie88
FTE Emeritus
Where is the stock turbo leaking that makes you want to replace it?
Old Jan 19, 2006 | 07:46 PM
puffer's Avatar
puffer
from the bottom and theres oil in the valley below it as well it also smokes above 15psi with the needle jumping
Old Jan 19, 2006 | 08:04 PM
cookie88's Avatar
cookie88
FTE Emeritus
So the one you are looking at s a rebuilt stock turbo with a different wheel? That should work fine, though it sounds like the new wheel will be less efficient than the stocker. May loose a couple of pounds of boost.
Old Jan 19, 2006 | 08:30 PM
puffer's Avatar
puffer
The guy mike claims instead of 8 fins it has 6fins witch will spool up faster and perform better than stock on bottom end and the same on top end
Old Jan 19, 2006 | 09:21 PM
cookie88's Avatar
cookie88
FTE Emeritus
Well.....I suppose since it costs half as much as a stock rebuilt it might be worth it, and from the looks of that site they do (or should) know a lot more than I do about turbos, but I wonder if you guys were on the same page during your conversation.
My stock wheel had 10 blades, and my aftermarket performance wheel had 10 blades, and my aftermarket performance turbo has 10 blades. And as far as I know, your wheel also has 10 blades.........
Old Jan 19, 2006 | 10:09 PM
puffer's Avatar
puffer
i thought mine have more than 8 but i haven't looked at my turbo, but i will talk to him again i will mention that., i asked him if its a garret he said of coarse it is just modded for better low end and the same top end
