Computer Chips & Tuners
74 Motor Just Stops
Old Jan 16, 2006 | 09:25 AM
BRONCO74's Avatar
BRONCO74
74 Motor Just Stops
I Have A 74 Bronco 302 Auto Trans Electronic Ign. I Have 1200 Mile On Complete Restore. Problem Is When You Driving About 10 Mins The Motor Just Stops ,just Like You Turned The Switch Off, If You Turn The Switch Back To Start The Motor Starts Running Again. Tryed 2 New Ign Switches With No Change.
Old Jan 16, 2006 | 09:36 AM
FTE Ken's Avatar
FTE Ken
Computer chips and tuners are available for 1986 and newer trucks only.
Old Jan 16, 2006 | 11:29 AM
BRONCO74's Avatar
BRONCO74
SORRY I PUT THIS IN THE WRONG TOPIC. DONT HANG ME YET I AM STILL NEW TO THIS
Old Jan 16, 2006 | 01:59 PM
SR_Crewchief's Avatar
SR_Crewchief
I had a 74 Gallaxie that would do that. IIRC there is an ingnition control module that is mounted on the wheel well that will shutdown when it overheats. Once it cools down you should be able to restart. The only fix is to replace the unit.
Old Jan 16, 2006 | 02:22 PM
BRONCO74's Avatar
BRONCO74
Have You Heard Of One Going Bad That Starts Right Bak Up? The Ones I Have Had Would Have To Cool Down.
Old Jan 17, 2006 | 12:21 PM
BadDogPSD's Avatar
BadDogPSD
Sure sounds like the ignition control module... I had a 77 Bronco that would stall out without notice. Often it would start right back up, sometimes it didn't! Put a new ICM in and the problem went away. Had the same problem with a 78 CJ5.
Old Jan 18, 2006 | 07:41 AM
FTE Ken's Avatar
FTE Ken
Closed. Folks... read my last post in this thread.
