orginal windshiled wiper pump
Look real closely at the firewall side and you will see a large thin nut threaded on the pump....just loosen it (after a liberal saturation of penetrating oil) and is should come off
the pump can then be removed from the cab
thanks,
also how do i get the head of the pump off? the part you put yout foot on? thanks I did not have time or lighting to look when i was after a pulley. thanks
Does anyone repo the rubber bellows assembly for this foot pump? Mine's about shot after 52 years. You'd think they'd last longer than that...
