Starting Trouble
Old Jan 16, 2006 | 06:02 AM
b_dog58's Avatar
b_dog58
Question Starting Trouble
I just got a '84 f150, great running, but on cold days
if it sits for to long it turns over, but doesn't start.
give it a shot of ether, and it'll start right up. any
help will be appreciated.
Old Jan 16, 2006 | 06:30 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Jan 16, 2006 | 06:39 AM
Dungeon_Master's Avatar
Dungeon_Master
Could be air leaking into the fuel line somewhere,choke setting,gummed up carb or injectors, or AIC is gummed if fuel injected.
Old Jan 16, 2006 | 07:24 AM
Neb86's Avatar
Neb86
I would look at the choke first. Does it snap closed when you open the throttle? It should. If it doesn't, find out why. If it's an automatic choke, it is closed with a spring that is inside round housing on the passenger's side of the carb. If it's a manual choke, check to make sure it goes completely closed when you pull the cable.
Another possibility is the gas is draining out of the fuel bowl when it sits for awhile. Before you start it, look down the throat of the carb and push the throttle all the way open and see if you get two good streams of gas being shot into the bore. If you don't the fuel bowl may be empty.
Good luck and let us know how you do!
Old Jan 16, 2006 | 08:23 AM
b_dog58's Avatar
b_dog58
thanks for the advice with the choke, i'll be sure to check
it out. doubt the fuel is draining out though, i only have
the problem when it's cold out. like this morning, 4 degrees!!!
Old Jan 18, 2006 | 11:45 PM
tsheriff's Avatar
tsheriff
Here is another tip. If it is an electric choke the key must be turned to the run position to actuate the choke. Turn key, smack gas peddal to floor, give it a half peddel shot of gas then turn key to start. Took me 2 months to learn how to start the GF's 79 bronco. I got to used to EFI.
