Sponsored by: Innova
PIE Help
Old Jan 16, 2006 | 01:45 AM
trackdayhauler's Avatar
trackdayhauler
PIE Help
So I received my FRD04-aux and blitzsafe installed it all no problems. Later to find out that I received the PIE for the 05 mustang with newer firmware after specifically requesting the PIE with the older firmware that doesnt cause problems on F series. Anyway, the vendor I purchased this from suggests contacting PIE to have them send me the correct piece. Has anyone done this. From what I read I get a circuit that solders to the main board back from PIE and not a whole new board. Problem is if thats the case, I dont think I have the soldering skills to put the new circuit in. Has anyone been through this process and have any insight on it?
Old Jan 16, 2006 | 07:26 AM
Don-T's Avatar
Don-T
I had the same problem. The factory radio would switch back to AM/FM after a couple of minutes. All you hav to do is replace a chip on the board, no soldering. You gently pry out the existing chip and carefully insert the new replacement.
Old Jan 16, 2006 | 10:54 AM
trackdayhauler
Awwwwwwwww yea. You just made my day, I was stressing on this. Thanks!
Old Jan 16, 2006 | 11:48 AM
2DLAKE's Avatar
2DLAKE
Yep, had the same problem, called PIE and the new chip was to my door in 3 days. 5 minute fix and works great now!
