Powerstroke transmission problem,help
Old Jan 15, 2006 | 06:02 PM
ccmonc's Avatar
ccmonc
We have a 1995 Powerstroke F250 automatic with 226000 miles. We have never had a problem with the transm. Always ran Mobil 1. Getting off highway, traveling on service road and heard a pop. Lost all forward momentum. Engine fine. No check light came on. Park works. But will not go forward or go in reverse. Suspect torque converter. Has anyone heard of this problem....?
Old Jan 15, 2006 | 08:33 PM
trike1946's Avatar
trike1946
Sounds like you are in for a rebuild. It might be something small, but with that many miles, once it is torn apart to find the problem you should do it all and be done with it. You can do a stock rebuild or beef it up. If you tow I would beef it up.
Old Jan 16, 2006 | 11:23 AM
GarryR's Avatar
GarryR
When a torque converter fails there is usually some indication with transmission problems chattering, slipping etc. unless the neck of the unit snapped. Pressure control valve? Dumb question but is the drive shaft still attached?
Old Jan 16, 2006 | 01:34 PM
gearheadz80's Avatar
gearheadz80
If the driveshaft came off he would not be able to put the truck into park while it was running. Sound like a rebuild time. Spend the xtra $ for the beef if you plan on keeping it for a while, youll thank yourself later.
Old Jan 17, 2006 | 10:59 AM
ccmonc's Avatar
ccmonc
thanks for the replys yes driveline intacked. trans fluid still clean have had no trans problems until this problem. in prosess of pulling trans. thanks mark
