Sponsored by: Real Truck
Clunk in front end
Old Jan 15, 2006 | 05:00 PM
spark9172002's Avatar
spark9172002
Clunk in front end
I have a 2003 F-350 Super Duty. I took it to the dealership because I heard a clunk in the front end when I ride over bumps. They replaced both upper and lower ball joints, both hubs, and sway bar end links. The clunk situation has improved but is not eliminated. The other day it was about 70 degrees outside and I didn't hear any clunking sound. The next morning it was in the thirties and the clunking sound returned. Any ideas???? My thought is the sway bar bushings or shocks. Will weather effect the performance of them?
Old Jan 15, 2006 | 05:49 PM
boxcar1974's Avatar
boxcar1974
It is the swap bar bushings. The OEM rubber are ok but there is movement in them. A good aftermarket eurathane bushing will take away the clunk.
I have a 03' and I have the clunk with OEM rubber bushing. As long as the bushing is not completely wore out (metal on metal) it will be fine.
Old Jan 15, 2006 | 06:40 PM
skipperm's Avatar
skipperm
SPARK, My son's 1999 SD had the "CLUNKS" too. Checked all the sway bar bushings and torqued all the bolts. Noise was still there. We then dropped the bar from the frame; drove truck and noise was gone. The solution in our case was to grind the surfaces of the frame and the mounting bracket (a build up of rust and corrotion of the coating on the frame apparently prevented a tight attachment) . Clunk is gone. Worth a shot.! Good luck.
Old Jan 16, 2006 | 06:57 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome spark9172002, to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
