Going back to dealer a third time
Old Jan 15, 2006 | 04:50 PM
wb6anp's Avatar
wb6anp
I was just looking over my engine for any slipping of turbo boost tubes, after towing my 12K trailer yesterday up a couple of hills that caused prolonged high boost (25 psi) pressure to maintain 55 ( cali speed limit, at 55 it wont shift down easily in tow haul, rpm's are too low), Looked underneath and saw coolant leaking from the right rear head area. I have only a 4" cat back exhaust on and no tuner. This is the second time for this problem the last time ( the same time last year after pulling my trailer) was a EGR cooler the second time it went in was for an epb sensor and vgt controller. I will let you all know what this problem is I'am not happy I have just over 16000 miles and was getting ready to pull my egr to look at it will have to do that later. Make that 4th time I also had a boost tube blow off when a clamp broke.
