Aftermarket Products
Sponsored by: Worksport
DeeZee organizer
Old Jan 15, 2006 | 12:38 PM
wickymustang's Avatar
wickymustang
DeeZee organizer
I got a DeeZee Tough Guy cab organizer for X-mas. The thing is, this hard plastic thing that sits behind the seat is supposed to be held in with 2 little pieces of double sided foam tape. Does this really hold? Also, the floor of the can has a shelf that is only 1/2 as wide as the organizer is, so when I load it without the tape on it it tips forward. Anybody put one of these in a 95 F150 single cab? Any ideas?
Old Jan 18, 2006 | 06:44 PM
wickymustang
Anybody? I am thinking about the only way is to rip down a 2x4 to fit the height and cut it to length and screw the board to the underside of the organizer?
Old Jan 21, 2006 | 01:35 PM
wickymustang
OK so I went ahead with that part, but now how can I firmly afix this to the cab? I was thinking of screwing it to the cab floor near the backwall. Anybody see any problems with this?
Old Jan 27, 2006 | 04:34 PM
wickymustang
Anybody know if this will work or if the plastic will get brittle enough in the cold winters to snap from having holes in it?
Old Jan 29, 2006 | 06:49 PM
wickymustang
Anybody got any input?
Old Jan 30, 2006 | 04:55 PM
tjc transport's Avatar
tjc transport
i ain't rite
i have had one in my 88 since it was 2 days old. since i never intented to, and never will sell the truck, i drilled through the top of the organizer and screwed it to the back of the cab with 3 large self tapper screws. may 11 will be 18 years it has been there, and it has always been full. never had a lick of trouble from it except being so full that i cant get anything more in it every now and then.
Old Jan 30, 2006 | 07:09 PM
wickymustang
So you had no trouble with the cold making it brittle? I was planning on screwing down through the bottom into the floor with 3 or 4 self tappers with some fender washers to spread the load.
Old Jan 31, 2006 | 07:39 AM
tjc transport
i ain't rite
nope. no problem at all. but then again, it IS 18 years old. and who knows if they cheapened up the formula between then and now.
Old Jan 31, 2006 | 08:01 PM
wickymustang
Did you put anything on the back of the organizer to keep it from rubbing the plastic trim? I was thinking maybe some sticky back felt strips used for furniture on hardwood floors.
