Hood Latch and grille modification ??
Old Jan 15, 2006 | 10:34 AM
broncman's Avatar
broncman
Has anyone modified the hood latch to a cable realease or some other method. I would like to eliminate the "rib" that veritcally blocks the grille from the hood latch. My truck is a 75 with AC and I want to add atranny cooler in the middle where the air flow is. I want the biggest cooler I can get because I tow in the mountains. Would converting to a 78 grill with the aftermarket tubular center give even more clearance? Would love a slim fan up front.
Old Jan 15, 2006 | 11:27 AM
User 71024's Avatar
User 71024
IF you don't have enough room, consider a cooler with an electric fan and mount it under the cab.
Old Jan 15, 2006 | 04:11 PM
broncman's Avatar
broncman
I have thought about that. Just would like to get as much airflow to it as possible. With the Super cab there is a ton of room under the cab though...
Old Jan 15, 2006 | 08:33 PM
User 71024's Avatar
User 71024
The way I figure it the less you put in front of the radiator the better off you are. We even moved the AC condensers on ambulences to underbody units to get the heat out from under the hood, made a huge difference in the summer.
Think if it this way, the oil cooler and the condenser are heating the air that goes threw them, raising the cooling air temp to the radiator.
