Sponsored by: Auxito
i need some help with spark plug change
Old Jan 15, 2006 | 09:33 AM
jadedsixx's Avatar
jadedsixx
hello everbody i need someone to help me, i changed all sparkplugs on my 5.4 engine 2001 ford f150 truck except for one was hard to get to it was on driverside second nearest one to firewall there is a what appears to look like aminature fuel filter all siver rails tubing with yellow ends along side COP attached right on top and its in the way of the bolt that holds the COP that says motorcraft I can see where this rail has two primary bolts but how do itake it off my socket can quite get the angle for small bolt holding the COP
jadedsixx's Avatar
jadedsixx
jtrtrrthhh
Old Jan 15, 2006 | 11:33 AM
Glock's Avatar
Glock
I use a 1/8" socket with a 1/8" breaker bar to loosen the nut.
The breaker bar was a lower profile then the ratchet.
Then I use a midget combination wrench to remove the nut. It take time.
Old Jan 15, 2006 | 02:31 PM
xtrford's Avatar
xtrford
remove the feul rail with a 8mm socket and then you can get to it, make sure you have a rag handy to soak the little bit of feul that will escape.
