Sponsored by: Auxito
New guy, need advice
Old Jan 15, 2006 | 08:26 AM
amaezing's Avatar
amaezing
I just purchased a 1999 F250. Love the truck. Only problem is, it came with only one key. Is there any way to program a second key without going to the dealer. I've read that programming a third key is no problem. Any help will be greatly appreciated.
Old Jan 15, 2006 | 11:51 AM
Beast12's Avatar
Beast12
Hi and welcome to FTE! Be sure to read this to help you around this site: https://www.ford-trucks.com/forums/s...88#post3272088 There are also State, Provincial and International Chapters located near the bottom of the main forum page.
We are glad to have you. Hope you enjoy the site. Check out the various forums. Lots of great info for you.
Thread moved to Super Duty forum.
See ya on the boards!
-Matt
P.S. I am sure the keys for the SuperDuty is just a regular key. They do not have the PATS system so any place should be able to make you a copy and it should work.
Old Jan 15, 2006 | 12:34 PM
jake00's Avatar
jake00
your local hardware store can cut one for you
Old Jan 15, 2006 | 01:01 PM
EnviroCon's Avatar
EnviroCon
I think '99-'00 F-250's came with PATS.
If thats the case, you could probably buy an OEM PATS key for it on ebay and any local key maker could probably cut it. But I think it would still require a dealer to erase and then reprogram both ignition keys.
Old Jan 15, 2006 | 01:50 PM
donjamer's Avatar
donjamer
I had a 99 F350 and it didn't take anything special to get an extra key. I just went to a locksmith and they cut it, gave me the key and it worked. No programming. I would assume it is the same for the F250's.
I was just wondering if you are talking about the keyless entry fob? That would be different and need to be programmed.
Old Jan 15, 2006 | 02:42 PM
mattd17's Avatar
mattd17
it might depend on if it is a 99 or a 99.5. i have a 99.5, and it is the regular key, no PATS. just try and have a regular key cut.... then you will only spend a couple dollars, and will know for sure.
Old Jan 15, 2006 | 03:21 PM
EnviroCon's Avatar
EnviroCon
If he has a '99 F-250 Light Duty, then he has PATS. If he has a '99 F-250 Superduty, he doesn't have PATS. Back in '99 they still made the Light Duty F-250. It has a GVWR of 8600# and looks more like the F-150. The Superduty's have a GVWR of 8800# and look like SD's from '99-'04. I've never actually seen a F-250LD in real life, I just know they exist.
Old Jan 15, 2006 | 03:31 PM
jello's Avatar
jello
EnviroCon is right on the money.
ps. I've seen an F-250LD in real life. (7 stud wheels)
Old Jan 15, 2006 | 06:33 PM
amaezing's Avatar
amaezing
Thanks for all the info
I do have a 1999 F250 light duty. I guess I'll have to have a key programmed.
Old Jan 15, 2006 | 06:35 PM
Beast12's Avatar
Beast12
Sorry I moved this to the wrong forum. I will move it to the proper forum.
Thread moved (again) to LD F-250 forum.
-Matt
