Vent window
Old Jan 15, 2006 | 01:59 AM
manza1sa's Avatar
manza1sa
Vent window
I am a *******, and locked my keys in my car. I ended up breaking the passenger vent window. I haven't checked it out yet, but i was wondering what i need to do to replace it. i have a 94' f150 and it It was 15 degrees out, and wasn't feeling like getting in my truck any other way. if any one can help, i would appreciate it.
Old Jan 15, 2006 | 10:04 AM
lv2race's Avatar
lv2race
Remove the inside door panel, you will see a bolt holding the wing window arm. Remove the bolt, slide the arm over and install your wing window. Takes longer to remove the door panel. Also, do you have a sliding rear window? If so, next time use a screwdriver and pop the slider lock and access the truck from there.
Old Jan 15, 2006 | 01:36 PM
manza1sa's Avatar
manza1sa
no i don't have a slider. I had a small block chevy go flying through my back window this summer, and almost had one put in...... if you can't tell i have had bad luck with glass and my ford. But thanks for the advice.
Old Jan 15, 2006 | 06:19 PM
mhg's Avatar
mhg
remove all broken peices and sealant holding glass in place
get new glass at glass shop and install using black silicone
