transfercase will not engage
Old Jan 15, 2006 | 12:54 AM
desratt's Avatar
desratt
if a front wheel speed sensor is bad will that not let my transfer case engage on a manual shift on the fly. ?
I get the indication light saying "4x4" and the auto locking hubs are working correctly.
Old Jan 15, 2006 | 12:55 AM
ford390gashog's Avatar
ford390gashog
i am confused. do you have esof or manual 4x4?
Old Jan 15, 2006 | 01:24 AM
desratt's Avatar
desratt
manual sof
but according to the shop manual it still senses speed and will only let the clutch in the transfer case engage into 4 high at speeds under 40mph and into 4low at speeds under 3 mph. I would have thought it would sense that through the instrument cluster.
this week I noticed a wire to my front passenger side wheel speed sensor was broke.
today I find out my transfer case won't engage.
Old Jan 15, 2006 | 01:29 AM
ford390gashog
i was not aware there was a speed sensor up front. you sure its not the abs sensor?
Old Jan 15, 2006 | 11:16 AM
desratt's Avatar
desratt
it is for the abs system but it is a wheel speed sensor..one for each tire. the abs does the 2 front tires seperately
