1978 - 1996 Big Bronco
Fuel pump woes...
Old Jan 15, 2006 | 12:13 AM
TakeEm's Avatar
TakeEm
Fuel pump woes...
My 86 Bko, 302 efi, aod has been just dieing when it feels like it and starting the same. I thought it was the inertia switch because of what it did last week. It died, I reset switch and still no start. I left and came back an hour or so later. Still no start. Jumpered inertia switch with paper clip and it fires right up. So, different switch put on.
3-4 days later it dies and leaves me stranded some 70 miles from home on hwy. No matter what I did, it wouldn't start. I towed it home. Still no start. 2 days later, I go to diagnose a no start condition and it fires right up 1st turn of key.
The next day, it dies closer to home. Jump FP circuit according to Haynes and both pumps come on. It fires up as it should. According to haynes, it is either wiring from FP relay to EEC or EEC is bad.
FP relay has corrosion in connector/wire side and wiring looks horrible. Bko stays running when playing with wires.
I put in a new Bosch type relay as I couldn't get new pigtail for OEM relay today, nor do I like the OEM relay. Now, pumps run continuously in key on position. The pumps don't shut off like their supposed to after a couple of seconds. It's wired like so: 30 pin- Yellow/hot wire, 87 pin- Brown wire to Inertia switch, 86 pin-Red wire to EEC relay, 85 pin-Tan/Lt Green wire to ECM.
I've noticed when key is on and pumps running, I can pull Yellow and brown wire off and pumps continue to run like it's hot wired. I don't think it's supposed to be like that.
Questions: Do I have a bad relay? Did I wire relay wrong? Can my EEC relay effect FP relay? Is ECM bad?
Any help would be greatly appreciated as I have to drive 160 miles round trip starting Wednesday for school and I can't afford to be stranded in middle of no where. Thanks again.
<!-- / message -->
Old Jan 15, 2006 | 01:43 PM
masseysbronco's Avatar
masseysbronco
Thumbs up
you wired the relay wrong, check out the pictures in my gallery, there is one of relays. The diagram is for something else, so just ignore one of the relays.
