1981 f100 interior
Old Jan 14, 2006 | 09:31 PM
frankyford's Avatar
frankyford
1981 f100 interior
I would like to know if the dash and door panels from the 92-96 model year will fit into an 1981 f100 lariat. I'm doing an upgrade on the interior and would like to make it a little nicer on the inside. thanks
Old Jan 14, 2006 | 09:44 PM
oldhalftons's Avatar
oldhalftons
the doorpanels wont. the DOORS will and you get rid of the 80-81 sliding door locks.
the dash will swap WITH the doors IF you have an auto. If its a stick you will need the 87-up pedal hanger assembly and convert to a hydraulic clutch.
the 87-96/98 dashes place the VIN in a differant spot than the 80-86, so you can't see it unless you put in a 87-96/98 windshield.
do you have a whole parts truck to work with?
Old Jan 14, 2006 | 09:50 PM
frankyford's Avatar
frankyford
yes it is an automatic, do you also know if I could swap out to a 92-96 steering column, I'm assuming i could considering I'll be using the same year dash. thanks
Old Jan 14, 2006 | 09:55 PM
frankyford's Avatar
frankyford
no i don't have a whole parts truck to work with, i got to replace the windsheild anyway, its got a big crack in it
Old Jan 14, 2006 | 09:59 PM
oldhalftons
a 87-91 column is a direct bolt in and plug in. the wiring changed in 92 and I don't know exactly how. the 92-96 column should bolt in.
giannakos444444
66
Jul 25, 2012 06:58 AM
ctindell1981
Jun 19, 2009 08:42 AM
timmgill
Sep 17, 2002 10:19 PM
Scott N
Jul 25, 2002 12:31 PM
timmgill
Apr 13, 2000 02:40 AM
