air pump
Old Jan 14, 2006 | 10:39 AM
150Flare92's Avatar
150Flare92
air pump
Is there supposed to be any resistance in the air pump pulley as you turn it? Mine as it is turn meets some risistance about 3/4 ways around then loose then some resistance.
Old Jan 14, 2006 | 11:14 PM
someday's Avatar
someday
i am not sure but that sounds like how a normal pump should work...there has to be a little resistance for the cylinder inside to pump air...if that is indeed how it is designed
Old Jan 15, 2006 | 07:16 AM
150Flare92's Avatar
150Flare92
Thanks/ Another thing is when running if you plug up the exhaust side of the pump it makes a rattle sound. Maybe it is going bad inside? It is a little too noisy for me at idle.
