code po356
Old Jan 14, 2006 | 12:50 AM
pageparsley's Avatar
pageparsley
Question code po356
can someone tell me what code po356 means. it says ignition coil f primary secondary circuit malfunction
Old Jan 15, 2006 | 06:48 PM
slc10844's Avatar
slc10844
Just a guess, but I think it may be a bad coil on #6 cylinder. It could be a wiring or PCM problem, but with all of the coil problems I would start there.
Old Jan 16, 2006 | 08:37 AM
projectSHO89's Avatar
projectSHO89
I'd have to agree with slc10844's idea.
To expand on it, the P035X codes indicate a PCM-detected problem with the primary side of the coil. Typical misfire codes (p030X) are set when the computer did not detect a primary side fault but did not find any crankshaft acceleration when it should have fired the cylinder.
Check the COP to make sure it is not unplugged.
Inspect the COP and connector for electrical connector issues such as corrosion or pushed pins.
Check reistance of primary coil to ensure it is not open.
If none of this fixes it, you will need the diagnostic procedure from the PCED to properly trace the fault and repair it. You can download a copy from www.fordcds.com
This assumes you have a 5.4 Since you didn't identify this vehicle by year and engine, I can only guess.
Steve
robin1t2002
1997 - 2003 F150
Apr 23, 2012 10:29 AM
JWA
Modular V8 (4.6L, 5.4L)
Mar 12, 2012 06:50 AM
sharpcar
Mar 22, 2008 09:54 PM
tmartinford
New Member Introductions
Apr 2, 2007 01:43 PM
pageparsley
Jan 14, 2006 08:46 AM
