ATF every fill up?
Old Jan 13, 2006 | 10:23 PM
73F100*8Mile's Avatar
73F100*8Mile
ATF every fill up?
ever heard of puttin a quart of atf to every fill up at the pump? supposed to help lube up injection system but i'm worried about carbon build up after repeated use. i know that they say pour a little bit of tranny fluid in throught the carb on gas engines to clean out carbon. what do you diesel guys think about this?
Old Jan 13, 2006 | 10:28 PM
rray32539's Avatar
rray32539
I wonder what the red color of the ATF would do to the diesel if and when you were stopped and checked for off road fuel in your tank. Off road fuel is dyed red. IMHO it's not a good idea, why not use Diesel Kleen instead?
ford390gashog's Avatar
ford390gashog
there is better stuff to use than 20w oil to lube the injection system.
Old Jan 13, 2006 | 10:54 PM
84deisel's Avatar
84deisel
here sometimes
I use the bio-deisel blend in my truck and it does the trick(smells nicer too!)it has extra lube for the pump already mixed in.
Old Jan 14, 2006 | 09:07 PM
bigredtruckmi's Avatar
bigredtruckmi
Veteran: Navy
I also use the bio at 5% been using it for 7 years. No problems. Smells great and runs quieter.
Old Feb 6, 2006 | 05:14 PM
schlager's Avatar
schlager
I always use 1 qt atf in my 1985 300td. Lots of old merc. people do this.
At least they do on the Merc forums. I also prime my new fuel filters
with ATF. The engine runs quiter, has more power and gets better fuel
milage. Also I do this in my 84 6.9l E350. I think my Mercedes would like
straight ATF if it could afford it.
Old Feb 6, 2006 | 08:46 PM
Larry_the_handyman's Avatar
Larry_the_handyman
That's a new one for me. I have two tanks, so I might start trying that in one of them. Right now I'm starting on a dual shot of chevron additive for diesel fuel.
Old Feb 6, 2006 | 09:08 PM
schlager's Avatar
schlager
LTH I put two qts ATF per tank in my 6.9l van. Don't put in every tank though but I do on my Mercedes. I also prime the new filters with it when I change them. I buy the cheapest ATF I can find. They don't know the difference. It seems to make a more noticable difference in the Mercedes. It sure does seem to clean the injecters up and spray better. I think I probably need to replace them on the MB. Can't seem to kill that old car. It just seems to run and keep running.
Old Feb 6, 2006 | 09:31 PM
jaybird's Avatar
jaybird
4ounces of ATF for every 20gallons will do the job nicely.If you put too much in you may find the truck may run a little rough or maybe not and you may find too much ATF will cause some smoking out the pipes.
Do a search online(IE google) you'll find ATF in diesels from way back years ago and you will find that using ATF additive in diesel fuel has been used succesfully for several several years and those old guys are still mounting up the miles on their ole timer diesels.
Old Feb 6, 2006 | 09:39 PM
mhannink's Avatar
mhannink
well ive run atf in some other diesels to clean the carbon off the injectors apperantly it has a real good detergent action idk but its seems like it would lube the system too. if you want ya'll could find an atf thats not red and run that so you don't get into trouble
Old Feb 6, 2006 | 09:44 PM
schlager's Avatar
schlager
I don't think the red will be a problem unless you run almost streight ATF. My MB would like that but it can forget it. When I prime a new filter though it sure likes that.
Old Feb 6, 2006 | 09:58 PM
roamer37's Avatar
roamer37
IF you think about this average 15 gallons of Deisel mixed with 1 guart of atf it is a 60 to I mixture its not going to change the color much if at all.
Old Feb 6, 2006 | 10:14 PM
mhannink's Avatar
mhannink
yeah but even the slightest red and the feds will nail ur *** to the wall for anything and everything they can
