Sponsored by: Auxito
Truck weight
Old Jan 13, 2006 | 04:34 PM
justinhorn's Avatar
justinhorn
Truck weight
I have a 03 Ford F150 Sport 4X4 XLT with the 5.4 in it and was wondering how much it weighs..the weight is not on the inside of the door.
Old Jan 13, 2006 | 04:35 PM
ford390gashog's Avatar
ford390gashog
the GVWR is on the sticker but curb weight varries. i suggest weighing it at a public scale, like the dumps or a highway patrol scale.
Old Jan 13, 2006 | 04:45 PM
justinhorn's Avatar
justinhorn
Thanks I'm just trying to figure out a general weight for both trucks to compare...
Old Jan 13, 2006 | 07:32 PM
kspilkinton's Avatar
kspilkinton
I have this for you... it's the specs sheet for the 2003.
https://www.fleet.ford.com/truckbbas...f150_03abb.pdf
In this pdf file is a worksheet to ballpark the truck's weight. It lists the options available and their weights. You start out with a base 119" wb shortbed truck which weighs 3,935lbs dry. You add all of your options, also figure you add the weight of all the fluids (gas, oils, coolant...etc). It shouild gived you a good idea.
The scale is the more precise way to go.
-Kerry
