Allright guys. I've got 1974 highboy, I'm going to be swapping in a 1978 f250 dana 44 w/diskbrakes. Now I was wondering if I could use my 74, 4.10 gears in the 78 I'm assuming that I can't but thought I'd ask. If so what will I need to use out of my 74 Diff.
Madmike33
ll
It will swap as long as the 78 is not a high pinion reverse ratio axle (which it may be)
I think it might be also, I posted a couple pics in my gallery of the axle, can you or someone check to see if it is, that is if you can tell just from looking at it.
