Sponsored by: Auxito
COP Repair
Old Jan 13, 2006 | 12:53 PM
plaid311's Avatar
plaid311
COP Repair
I just found out that I have the P0301 code on my '99 F150 4.6, and I want to get the coil and plug replaced for Cylinder 1. I understand that this is a purely subjective question, but is $348 to get this replaced from a Ford dealership the equivalent of getting raped? I have a feeling that it is. Is just replacing the plug on cylinder one a pretty quick process since it's an easy access cylinder? I've read many posts on people with this problem, so I know that it's most likely a coil and/or plug. Oh, and a wire/plug job at the Ford dealership is a whopping $470, which I just can't seem to justify. Other local shops (Firestone, Pep Boys) will do it for between $250 and $300. Any opinions on pricing and such would be much appreciated.
Old Jan 13, 2006 | 01:05 PM
plaid311's Avatar
plaid311
....follow up....
Oh, and are there any threads on the site that show how to replace a COP? I guess it would pretty much be the same process as a plug, but I'm making sure.
Old Jan 13, 2006 | 01:14 PM
jbabbler's Avatar
jbabbler
There's one in the sticky for changing plugs. Just stop when you get to the part about the plugs.
Old Jan 13, 2006 | 01:31 PM
plaid311's Avatar
plaid311
Well, I just read that the 4.6's do not have COP's, so is it possible for the problem to still be coil-related since the scan code only indicated cylinder 1?
Old Jan 13, 2006 | 02:15 PM
92merc's Avatar
92merc
Possible, but those ignition packs don't go out that often. I'd be more inclined to believe plug wire and/or plug issue.
Old Jan 13, 2006 | 03:07 PM
mat-helm's Avatar
mat-helm
The coil packs are about $40 bucks at advance. But in my case it was water n crap down in the pulg holes. I would start by pulling the wire on 1 to see if it's nice n dry. If so I would replace the one plug ( and replace the other one's later if this fixes the prob). If you've read a lot of threads on this, then you know it could be a lot of things causing this.
steeltown08
Mar 27, 2017 06:08 PM
HBE86
Jun 10, 2015 09:34 PM
vanvoorenfamily
25
Nov 13, 2011 11:39 AM
mikejaros
Oct 6, 2011 01:30 AM
7mag
Modular V8 (4.6L, 5.4L)
Aug 22, 2009 02:51 AM
