1978 - 1996 Big Bronco
New Here, 95 Bronco Problem-Speedometer
Old Jan 13, 2006 | 09:54 AM
TJSmoot's Avatar
TJSmoot
First let me say I'm glad to finally find a Ford truck board. Now lets get down to business.
I have a 95 Bronco Eddie Bauer with the 351. It's never given me a prblem until now. Yesterday I was towing a light trailer down the interstate when my speedometer fell to zero and it shifted out of overdrive. The ABS light came on and the overdrive OFF light started flashing. I shifts really hard now at all shifts up and down. And of coarse the odometer stopped working too.
Is this a common thing? Anyone out there know this one right off their head? I've never taken a vehicle to a dealership ( I've worked at three ) for anything and I don't want to have to start now. So, any guesses, VSS, something electrical, speedometer cable or gauge itself ? Any hepl would be great. Trying not to spend $100 on diagnosis at the stealership.
Old Jan 13, 2006 | 10:01 AM
wlihntr's Avatar
wlihntr
the VSS is a common problem of ford trucks. it is on the top of the rear diff and should be about $25-$30 at the dealer. i would try that first
Old Jan 13, 2006 | 12:16 PM
TJSmoot's Avatar
TJSmoot
That's kinda the direction I was leaning as well, but I've seen were others had the same problem and the dealership couldn't fix it. This made me worry that maybe there is more to it than I know. Seems almost too simple to me. Probably shouldn't have added that part, might have jinxed myself. Anyone else have any input, agree or disagree?
Old Jan 13, 2006 | 12:35 PM
Torque1st's Avatar
Torque1st
Posting Legend
Hello- Welcome to FTE! I have moved your post to the specialized forum we have here for your question. Check out the list of tech forums we have here. There is a wealth of information and expertise here to help you. There are a number of links in my sig below to help you also. Have fun!
Old Jan 13, 2006 | 05:18 PM
Streetgang's Avatar
Streetgang
The flashing of the OD off light on the end of the shift stalk indicates that there is a fault in the tranny.....and that there are codes stored. That would be my very first move.....pull the codes. The hard shifts all tell me that the trans 99% sure you have a E4OD is in "safe" or "limp home" mode so as not to mess itself up any worse.
Yes it could be the VSS (that would be a easy and cheap fix), but it could also be something else, and it would be just stupid to start throwing parts at it.
Old Jan 13, 2006 | 05:56 PM
Snake1979's Avatar
Snake1979
When the fuse blew for the dash in my 150, it did same thing. It did stay in OD however, but did flash repeatadly. I thought about taking it out on a long trip, because the mileage doesn't add up.
Old Jan 13, 2006 | 05:58 PM
aurgathor's Avatar
aurgathor
I'd check the rear axle and the VSS connections first -- remove the fill plug and see if you have a substantial amount of metal shaving stuck to it, or not. If it's clean check the VSS with an ohm meter, and check the connector for possible corrosion/bad contact.
Old Jan 13, 2006 | 06:08 PM
TJSmoot's Avatar
TJSmoot
Thanks for your help so far guys. Am I right to think that on a 95 you have to use Ford's scan too to pull codes? The generic ones won't work will they? I called the dealership today and they said that they would have to charge me $75-$150 for diagnostics. I can fix it myself I just can't see paying that much to pull codes.
Old Jan 13, 2006 | 06:30 PM
TJSmoot's Avatar
TJSmoot
Oh yeah, I forgot to ask. Is there a way to get the codes without a scan tool, like a self-check, flash code kinda thing?
Old Jan 13, 2006 | 07:22 PM
Streetgang's Avatar
Streetgang
You can do it with a paper clip if you want. Click on this link and there will be more info than you need on exactly how to do it.
http://fordfuelinjection.com/?p=13
Oh yea.....you can buy your own OBD2 scan tool for under $100......just shop around. Or most auto parts joints will pull your codes for free!
Old Jan 13, 2006 | 07:48 PM
TJSmoot's Avatar
TJSmoot
Will an OBD2 scan tool work on a 95 Bronco? I've never seen a connector for an OBD2 scan tool on my truck.
Old Jan 13, 2006 | 07:52 PM
Streetgang's Avatar
Streetgang
This is exactly what you need.......you have OBD1.
http://www.etoolcart.com/index.asp?P...OD&ProdID=3758
Old Jan 14, 2006 | 01:18 AM
Firefighter sta 19's Avatar
Firefighter sta 19
there is alo a fuse under the dash for the interior lights that it could be
Old Jan 14, 2006 | 07:50 AM
Streetgang's Avatar
Streetgang
ummmmm.....what????
Old Jan 14, 2006 | 09:21 AM
Snake1979's Avatar
Snake1979
Thats what I said when I replied, but it won't make it shift out of OD, the light just flashes. The speedometer quits working, the mileage doesn't show. Exact symptoms just reported except for shifting out of OD. Its just a fuse in the fuse panel under the dash on the right side. Might be a 95 thing, I've got a 95 f-150 that it did it in.
