vin#s sequence
Old Jan 12, 2006 | 10:17 PM
ragweedfan's Avatar
ragweedfan
vin#s sequence
where do you find the rear end id# on the vin #, looking online for a 5.4 a/t 4x4 with 3:73 gears. been looking for a truck for 3-4 weeks and all that i have found thus far have been 3:55s. this site has my head spinning with numbers but a ton of good info to be learned. thanks too all
Old Jan 13, 2006 | 11:09 PM
bigwobbely's Avatar
bigwobbely
wish i knew but you can look at the rear end and it should have a tag on it that says what gears the truck has. also the window sticker will say this 2. wish i could have helped more. and if all else fails when u buy a truck have the dealer put the gears u want in before u pick it up.
Old Jan 14, 2006 | 10:50 AM
Dazz's Avatar
Dazz
On the '04 F-150 the "rear end" ID# is found in the Vehicle Certification Codes located on the door decal. The VC Codes are shown just below the bar codes. Your "rear end" ID# will be under "AXLE". Code 26 means 3.73 non-limited slip. Code B6 means 3.73 limited slip.
