Instrument cluster not working
Old Jan 12, 2006 | 08:26 PM
bpi328's Avatar
bpi328
Question Instrument cluster not working
I have a 1992 F-150. My speedometer, fuel, tach, oil, and temp gages are all not working. They either show a false reading or don't work at all. My speedo is pegged out all the way past 80 mph. The Tach doesn't read any RPMs. My Odometer was also out, but I found that to be fixed by a blown fuse. I have checked all of my fuses and have found no other ones blown. Is it in one of the relays? I don't know how to check those. Any information you could provide would be greatly apprieciated.
Thanks a lot!
Old Jan 12, 2006 | 11:10 PM
Torque1st's Avatar
Torque1st
Posting Legend
Hello- Welcome to FTE! I have moved your post to the specialized forum we have here for your question. Check out the list of tech forums we have here. There is a wealth of information and expertise here to help you. There are a number of links in my sig below to help you also. Have fun!
Old Jan 13, 2006 | 08:29 AM
KW160's Avatar
KW160
Maybe something in the cluster is making bad contact? Ground or +12V perhaps? I'd suggest removing the cluster and inspecting all the connectors and the laminant circuit sheet in the back of the cluster. Maybe one of the connectors is loose and making bad contact.
Old Jan 13, 2006 | 06:46 PM
67aj's Avatar
67aj
Bad connection
I had the same problem. Make sure all of your fuse in the fuse panel locate under dash on drive side is push all the way in . I found a loose fuse
Old Jan 18, 2006 | 11:18 PM
bpi328's Avatar
bpi328
Thanks guys. I went back through my fuses and found one was cracked on the top. That took care of my problem.
Rentaro
Jul 21, 2014 09:31 PM
DenverF150
Dec 19, 2011 12:03 AM
Steveg13
Nov 23, 2009 12:43 PM
jcv44wf
Mar 28, 2004 12:15 AM
Ddog1023
1983 - 2012 Ranger & B-Series
Mar 26, 2004 01:31 PM
